MK7 transit p0341 fault code
Postby flk2006 » Fri Feb 16, 2018 2:50 pm
can anyone help please? have a 2014 mk7 transit 2.2 duratorq in at the minute, the revs sit at 1000 on idle with the DPF/transmission light on the dash, no engine warning light, and it wont rev above around 2000 and if you jam the throttle it hunts. i have looked online and have replaced:
Camshaft Sensor
Crankshaft Sensor
Camshaft sensor wiring
Batteries
Alternator
Starter Motor
PCM (and have coded it to immoboliser so that engine runs)
Glow Plug Module
Checked the timing
inspected the tensioner and belt
inspected the camshaft itself
I have also checked the voltages getting to the sensors and compared them with a working wagon, as well as carrying out a complete continuity check of the entire engine loom.
The fault is still there and i have run out of ideas, can anyone help please :?: :?: :?:
flk2006
Re: MK7 transit p0341 fault code
Postby flk2006 » Tue Feb 20, 2018 12:11 pm
bump anyone out there?????????????????
flk2006
Postby paul2012 » Tue Feb 20, 2018 10:12 pm
P0341 Camshaft Position Sensor "A" Circuit Range/Performance.
Possible wiring fault or faulty sensor
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby flk2006 » Mon Feb 26, 2018 12:41 pm
as stated in description we have checked the wiring.
flk2006
Postby Lee m » Thu Feb 07, 2019 7:58 pm
Did you find the fault? My van is doing a similar thing.
Lee m
Postby Lee m » Thu Feb 07, 2019 8:00 pm
Also what should the voltage to the sensor be?
3 wires going to the sensor 1 of the is earth and I getting about volts to the other 2 wires. Should 1 be 12 volts?
Lee m
Users browsing this forum: knobby1
