toppetsaha wrote:Just a quick thought, if i were to find a 120ps ecu which was from the same year truck as mine (2001) would this be compatible with my current setup providing that i could get it re mapped, possibly by vantuner?
bambi mk 1 wrote:You will need the cab loom,the engine bay loom plus the clocks .There may be other options by flashing the ecu but with a mish mash of looms it might not work.I presume you used the loom that came on the new engine
bambi mk 1 wrote:I think that will complicate things further as the early vp 44 pump wont work with the later loom as the pin layout is different
