01 Transit tourneo, been in storage a year, started it found clutch stiff on engaging pedal was slow coming up, fluid has started pissing out slave now too, I can put it in gear and roll the van by hand!!! so presume clutch plate has stuck engaged ??
Now presume that’s made clutch slave pop? Or is slave stuck engaging clutch,It’s firing out the nipple bit the rubber cap goes on when press clutch, clutch pedal still stiff
Quite gutted as van was fine when driven in there lol
