Strange ASM hissyfits.
Postby Aussietransit04 » Sun Feb 18, 2018 12:54 pm
:roll: I have a problem with my '04 125 T330 ASM.When I turn the ignition "on" I get this grinding noise.I suspect it is when going from park (1st gear) into neutral.The same noise when I turn it "off".
2nd:It has started to thump into gear or hesitates to change gear or stays in 1 gear without changing up or down in particular 3rd gear.If I pull over,restart the engine,it seems to reset itself.Periodically the gearbox goes into neutral when I turn a corner and stays in neutral,again restart the engine and it has reset itself,then all good until the next episode Strange?it is only intermittent not permanent.
Is it a computer problem or fault with the auto select.
Aussietransit04
Re: Strange ASM hissyfits.
Postby ossie cossie » Sat Mar 31, 2018 12:43 pm
there are a few threads on here about ASM issues, i have got problems with mine as well, intermittent like yours.
ossie cossie
Users browsing this forum: Google Adsense [Bot], W3C [Validator]
