Gearbox crunch/grind
Postby TheTwoToneRebel » Sun Feb 18, 2018 4:15 pm
Hi i have a 2002 ford transit T280 2.0td FWD.
basically it drives ok it just could be better the problem i am having is when i select 1st gear i need to raise the clutch a little before it will go in and sometimes when at junctions it feels like its in first but when i lift the clutch pedal it crunches and i have to put pressure on the gear lever to get it to go in 1st gear.
another problem is when i'm driving and try to go from 2nd to 3rd it will crunch unless i change gear really slow and sometimes it just crunches anyway, if i'm going down from 4th to 3rd its the same it will crunch unless i change down stupidly slow.
all the rest of the gears are fine its just 1st and 3rd i have a problem with i have replaced the clutch and changed the gearbox oil but there was no change.
Many Thanks, Jay.
TheTwoToneRebel
Re: Gearbox crunch/grind
Postby ake » Sun Feb 18, 2018 4:47 pm
gear selector cables will be worn and need replaced
Postby TheTwoToneRebel » Sun Feb 25, 2018 12:48 pm
Hi, Thanks for the reply. I will order a new set and post the result on here i really hope it works ha ha. Thanks Jay.
TheTwoToneRebel
Postby v8dave » Sun Feb 25, 2018 1:40 pm
Could also be an issue with the gear selector turret on top of the box.
Have a look in the technical how-to section :- viewforum.php?f=18&start=50
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Postby TheTwoToneRebel » Tue Mar 06, 2018 3:24 pm
Hi, i checked the turret and it moves around freely, i have the cables on order im just waiting for them now.
do i have to adjust the cables or are they a standard size? Thanks, jay.
TheTwoToneRebel
Users browsing this forum: alfsav, Google [Bot], knobby1
