central locking problem help please
Postby Mankeydeath39 » Sun Feb 18, 2018 5:14 pm
Hi folks, I'm new to the forum and have a 2008 lwb 2.4 tdci van, I have a problem with my central locking it blows the fuse every time I try to lock it! If I disconnect the rear door and replace the fuse the locks will lock then open again but when I reconnect the back door and lock it the fuse blows any ideas what's going on, I've checked the wiring loom and no broken cables, really want to get the locking working again, can I use a volt metre to test if so how? Thanks in advance guys
:D
Mankeydeath39
Re: central locking problem help please
Postby ake » Sun Feb 18, 2018 5:15 pm
have you checked the wiring loom for short circuits?
Its the most common cause of central locking problems on mk7
Postby Mankeydeath39 » Sun Feb 18, 2018 6:32 pm
Hi yes checked and followed back to front door pillar no breaks in any cables :(
Mankeydeath39
Postby v8dave » Sun Feb 18, 2018 8:42 pm
Check the loom between the rear door and the rest of the van.
They are well know for failing inside the tubes that carry the wires into the door.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Postby Mankeydeath39 » Mon Feb 19, 2018 8:48 am
Checked there no short, is it possible its the actuator?
Mankeydeath39
Postby v8dave » Mon Feb 19, 2018 1:01 pm
Probably, the van knows the rear door does not lock when it is connected which is why it unlocks when you connect the actuator.
Can't look up the wiring at the moment, can send you the pin functions on the lock unit this evening.
v8dave
Postby Mankeydeath39 » Mon Feb 19, 2018 4:41 pm
That would be helpful v8dave,
Been and checked loom again still no breaks but also noticed side door doesn't lock as well.
Have found a random red wire which isn't connected at one end and traced it to a relay under the dash, so confusing
Mankeydeath39
Postby v8dave » Mon Feb 19, 2018 8:10 pm
Colour codes are the normal
GY - Grey
GN - Green
YE - Yellow
VT - Violet
BU - Blue
WH - White
OG - Orange
BK - Black
v8dave
Postby Mankeydeath39 » Mon Feb 19, 2018 9:09 pm
Thanks for this, will get on with voltmeter tomorrow, will update then :)
Mankeydeath39
Postby Mankeydeath39 » Tue Feb 20, 2018 1:15 pm
Thanks v8dave, used your diagram to sort problem all working well, turns out last owner had made his own wiring loom but mixed up wires :o I have rewired loom correctly and presto central locking. Thanks for help hope I can return favour :D
Mankeydeath39
Users browsing this forum: Google [Bot], gt_addict
