Karst wrote:Thank you Altransit..... Will be checking them imminently.....
invernessguy wrote:I’m sure the dealer will repair it for you Sent from my iPhone using Tapatalk
Karst wrote:Hi Altransit, invernessguy, and knobby,
Thank you for your answers
I passed by my trusted mechanic of many, many years today and asked about the sound of the engine, and he said it is completely normal for a Mk7 engine. Do you still think I should check the injector clamps?
BATTERY SPARKS ..... When I reconnect the battery, is it normal for big sparks to jump across, or is it a sign of an abnormal drain?? Don't seem to get the same sparks when I disconnect.
REVERSE GEAR ...... Does a Mk7 have a dodgy reverse gear? This one has only done 80,000 miles. This evening I suddenly couldn't get reverse gear. Am I not pushing the lever over enough, before I pull it back into reverse??
Karst.
Karst wrote:Does anybody know specifically where I could get either a new or good second hand main floor mat?
mike10 wrote:Karst wrote:Does anybody know specifically where I could get either a new or good second hand main floor mat?
Try here: https://www.fordpartsuk.com/rubber-floor-covering-rhd
It says it is for a Southampton built van, but when I contacted them they said the only difference they could see between that one and the one for the Turkey built vans was a very slight difference in colour. Looks like the Turkey built ones are out of stock though as they are only listing the one in the link at the moment.
Users browsing this forum: Google [Bot], sfnett
