Alternator fault i've not seen before
Postby cphaza » Sun Feb 18, 2018 10:27 pm
Hi guys
Got a strange one with a late mk6 2006 2.4. The battery isnt charging but i have no battery light. When i say no battery light i mean nothing at any time - ignition on engine off, engine on, idle, at revs - no light and no charge. Has anyone come across this before ? I have tried taking the plug off the back of the alternator to 'disconnect' from the smart charging system to get it to run like a normal system - still no joy. Anyone got any ideas? Posted this else where on the site, hopefully this is in the right section now!
Chris
cphaza
Re: Alternator fault i've not seen before
Postby Frag » Mon Feb 19, 2018 1:20 am
Could be as simple as the bulb blown in the cluster,
Or,the RWD mk6 has a few fuses and relays in the charging system,or broken wire to the 3 pin smart charge plug.
Have you done any work to it recently ?
There's a main feed to alternator which comes from main starter terminal,people have been known to miss this wire after starter motor work.....
Frag
Ford Technician
Postby inasinman » Mon Feb 19, 2018 6:11 am
Possible faulty earth cable. It has a fusible link, overtime the metal can fatigue and loose charge. You can test by earthing your battery negative terminal to the chassis.
MK6 125/350 LWB 2.4 RWD
inasinman
Postby bambi mk 1 » Mon Feb 19, 2018 9:50 am
inasinman wrote:Possible faulty earth cable. It has a fusible link, overtime the metal can fatigue and loose charge. You can test by earthing your battery negative terminal to the chassis.
The van is starting so wont be the fusible link :roll:
Op have you checked the alternator for power at the connections :?: The wiring over the timing cover can break :idea:
bambi mk 1
Postby scas » Mon Feb 19, 2018 10:36 am
also check the wiring that runs from the alternator across the top of the engine,thats held by the plastic cover, wires can fray due to vibration.
06 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 90
05 mk6 2.4 di 115
new 06 mk6 2.4 di 115
new 00 mk6 2.4 di 125
can you see a pattern
scas
Postby bambi mk 1 » Mon Feb 19, 2018 9:51 pm
scas wrote:also check the wiring that runs from the alternator across the top of the engine,thats held by the plastic cover, wires can fray due to vibration.
Somebody else said that already :wink:
bambi mk 1
Postby ned » Mon Feb 19, 2018 10:03 pm
Maybe they couldn't understand your accent :wink: I get that a lot when writing letters :lol: :lol: N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby transit2015 » Tue Feb 20, 2018 7:41 am
Alternator's slip rings worn out or voltage regulator's brush broken.
I had similar fault battey light was on only short time afrer that no light anymore...
transit2015
Postby scas » Tue Feb 20, 2018 1:09 pm
i need glasses :roll:
04 mk6 2.4 di 90
05 mk6 2.4 di 115
scas
Postby ned » Tue Feb 20, 2018 6:48 pm
scas wrote:
ned wrote:
bambi mk 1"quote="scas wrote:also check the wiring that runs from the alternator across the top of the engine,thats held by the plastic cover, wires can fray due to vibration.
i need glasses :roll:[/quote]
You can borrow mine :wink: I can't see out of them :lol: N
ned
Users browsing this forum: Loudpipes, Majestic-12 [Bot]
