Working out my 2008 electronic Turbocharger for 2007 transit
Postby Phemmy » Tue Feb 20, 2018 10:51 am
hello friends, I just got a new engine for my 2007 Ford transit and it came in with the 2008 electronic Turbocharger.
The issue now is where the electronic wiring leads to as the former engine does not have the electronic part.
Phemmy
Re: Working out my 2008 electronic Turbocharger for 2007 tra
Postby loot » Tue Feb 20, 2018 11:15 am
You have the wrong engine then!
The electronic turbo is fitted to the 130ps 140ps engines mainly.(Earlier euro 4 anyway).
I assume your new engine is second hand and is built up? You have injectors fitted?
You might be able to swap the turbo to the old manual 1 and the injectors too. If you plan on keeping this engine and turbo then you'll need to add the loom and probably the pcm/or reprogram it.
I've not done this conversion personally so it's just my thoughts, there will likely be others that have though :-)
Ids map here
loot
Postby Phemmy » Tue Feb 20, 2018 7:38 pm
The engine is for 2008model, but couldn't figure out where the electronic Turbocharger derived it's power source.... Any info on this would be helpful.. thanks.
Phemmy
Postby paul2012 » Tue Feb 20, 2018 9:15 pm
Phemmy wrote:The engine is for 2008model, but couldn't figure out where the electronic Turbocharger derived it's power source.... Any info on this would be helpful.. thanks.
Direct from PCM (Engine ECU). Even if wiring was there for it. Turbo wouldn't work until PCM has been reprogrammed with correct calibration :idea:
Project 2003 Transit mk6 T280 - mk7 2.2 TDCI engine conversion
2015 Vauxhall Astra Tech Line GT 2.0 CDTI 165ps
Ford IDS PCM updates Fuel pump/Key coding services
SUBCRIBE to my YouTube channel https://www.youtube.com/channel/UCoEIqO ... 3qiAsAq_8w
paul2012
Postby knobby1 » Wed Feb 21, 2018 11:18 pm
What PS is the original engine..?? Agree with loot and Paul...you've probably got the wrong engine. :(
