Hi, I have a Ford Transit 2.2 litre diesel of 2008.
I changed the battery last week and since then the interior lights cannot be swithed on anymore while ignition switch is in position 0 or 1. With the ignition switch in position 2 everything functions normal, and also with the motor running nothing is unusual. The radio also only functions with the ignition switch in position 2. When the ignition switch is put to position 1 or 0 the radio is directly switched off and all pre-settings are lost.
What could be the cause of this?
