MartinB wrote:I plan to tap off the little red light in the speedo and install a new bright light in an empty switch housing. I found my way into the instruments (very useful video on YouTube) and was sure I found the right wire (red and yellow) but that's not it.
richgold wrote:MartinB wrote:I plan to tap off the little red light in the speedo and install a new bright light in an empty switch housing. I found my way into the instruments (very useful video on YouTube) and was sure I found the right wire (red and yellow) but that's not it.
Crazy idea.
Why not just try remembering to shut your doors?
Much easier.
MartinB wrote:V8dave, thanks but you don't help. Don't know what bcm or can bus means or where they are. So could my plan work if I find the right wire?
bambi mk 1 wrote:Your interior lights stay on when the doors are open Look up my good man
knobby1 wrote:bambi mk 1 wrote:Your interior lights stay on when the doors are open Look up my good man
Not if you turn 'em off..!
loot wrote:I've got a big arse red Switch between my drivers seat that disconnects the powerall system inverter, power converter and lots of led strips in the back, my bulkhead hides it all and 9 times out of 10 I turn it on to use the back for changing clothes, take a sh*t or whatever but I forget to reset the handle in the front It can be a week that it is all left on before I jump in the back again and realize I've left it on so a little light on the dash sounds like just the ticket or ignition switching or something else maybe a hole in the bulkhead?.
v8dave wrote:THERE IS NO RIGHT WIRE.
v8dave wrote:Go for it Loot.
At least you know what bcm and canbus mean.
