electrical circuit board in fuse box
Postby Mike85 » Fri Feb 23, 2018 2:03 pm
Hi Folks
bought a mk6 2.4 couple of weeks ago and only getting round to sorting a few things on it now, reverse lights had quit working on it so decided to check fuses under the bonnet and found this wrapped in electrical tape in the fuse box, anyone any idea what it is? looks like it takes a feed from a fuse terminal and another wire soldered onto a black wire with a red trace on the main loom.
Mike85
Re: electrical circuit board in fuse box
Postby Frag » Fri Feb 23, 2018 2:56 pm
Looks like an intelligent split charge relay..
Have you got a towbar with twin electrics,or a aux battery elsewhere on the van.?
Frag
Ford Technician
Postby Mike85 » Fri Feb 23, 2018 7:23 pm
No fancy towing electrics or second battery on this one, bit more of a look and it seems to be wired into the abs pump
Mike85
Postby knobby1 » Fri Feb 23, 2018 10:26 pm
Mike85 wrote:No fancy towing electrics or second battery on this one, bit more of a look and it seems to be wired into the abs pump
Aftermarket "hill assist" maybe..??
Postby Altransit » Fri Feb 23, 2018 10:30 pm
:idea: Maybe locks the brakes on if it's triggered? Part of an alarm system :?:
Postby loot » Fri Feb 23, 2018 10:46 pm
It's a comparator circuit :-)
It will switch at a voltage that you set it to hence the blue box with screw, that it the pot for it.
So it could switch when the engine is on charge from running, maybe for charging tools but only when the engine is running eg.
Or it's a latching relay :lol:
That's what I think anyway :D
Bloody Maplins.
https://m.ebay.co.uk/itm/12V-Auto-Circu ... Sw8-xZwis~
Ids map here
loot
Postby motorman116 » Sat Feb 24, 2018 7:29 am
loot wrote:It's a comparator circuit :-)
Bloody Maplins.
:shock: The abs doesn't work and its, to turn on / off the ABS light for Mot purpose :?:
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
Postby ned » Sat Feb 24, 2018 8:09 am
This van in question its not ex AA/RAC is it. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby loot » Sat Feb 24, 2018 9:07 am
Bloody Maplins.
Sounds right so ignition on abs stays lit, engine runs and abs light goes out.
So it'll be a comparator then? :-)
Unless the abs light comes on and goes out before the engine runs in which case it's a timer relay but an old setup. :?
Ids map here
loot
Users browsing this forum: grego
