Question regarding engine swap
Postby dannysconnect » Sat Feb 24, 2018 11:25 am
Hi guys
Not been on here for a while
Long story short
My brother has a 55 plate 2.0 tdci transit
His engine died so I swapped it with another
The engine I swapped it with was from a mondeo MK3 ( I didn't realise this until removing the injectors to find that they were the shorter nozzle injectors)
My question is, does the mondeo mk3 2 litre tdci engine with the shorter injectors work in a transit van? I.e. Is the ECU and injection driver set up to work the same for transit and mondeo engines seeing as they injectors are different sizes?
Car Van servicing, diagnostics & Electrical
Cover Berks and Bucks and West London area
dannysconnect
Re: Question regarding engine swap
Postby wojciech » Sat Feb 24, 2018 6:01 pm
dannysconnect wrote:Hi guys
Long story short
wojciech
Postby wojciech » Sat Feb 24, 2018 6:28 pm
dannysconnect wrote: My question is, does the mondeo mk3 2 litre tdci engine with the shorter injectors work in a transit van? I.e. Is the ECU and injection driver set up to work the same for transit and mondeo engines seeing as they injectors are different sizes?
Yes, it will work ok. You must only encode new injectors into old, genuine Transit PCM. Injectors are very similar with the same construction inside (Transit 2,0 tdci/Mondeo 2,0 tdci after lift 06.2003), in Mondeo they have shorter sprayer or inside are different reducing pipes in initial chamber, steering chamber etc... This differences are coded in 16 alphanumeric characters number, written on injector.
wojciech
Postby dannysconnect » Sat Feb 24, 2018 10:17 pm
Thank you very much for the info mate
dannysconnect
Users browsing this forum: knobby1
