couple of questions
what oil grades and amounts are needed
how to drain the box and diff. do they have drain plugs ? is it remove the rear diff case ?? does it have a seal if so
2010 RWD 2.4 tdci 115
cheers guys
v8dave wrote:Gearbox oil is specified as WSD-M2C200-C
A service refill needs 2.2 litres, from dry you need 2.4 litres.
Axle oil is specified as WSL-M2C192-A
Capacity is 3 litres.
Torque is 50Nm
Torque is 35Nm
Axle oil drain is by removing the rear cover, there is no gasket.
You need to seal it back on with a sealant to WSS-M4G320-A3 ( I can't find an equivalent but Loctite recommend 5910 for this )
The bolts are torqued to 61Nm.
There is apparently a filler/level plug.
blue estate wrote:yes there is and it's handily a 3/8th square
maccavvy wrote:so e75w90 for gearbox and 75w140 for diff then ...thanks for your help guys
