Offroad tyres
Offroad tyres
Postby axam102 » Sat Feb 24, 2018 10:31 pm
Hi All, currently running 215/75/16 road tires on the beast but she likes to chew the ground up a bit :roll: we just sink until we hit bedrock :shock: . I have few races coming up which will see me siting in a field in the middle of nowhere on wet grass. The old girl is a mk6 350 RWD and I will get frowned upon for plowing furrows... any good recommendations for off road tires with the correct weight rating?
axam102
Re: Offroad tyres
Postby neoxerox » Sun Feb 25, 2018 1:30 am
I've fitted 225/75R16 BF Goodrich A/T KO2's to my MK7. They're 115 load rated (1215kg). No rubbing/clearance issues, they are noticeably closer than stock on the front though.
The 215/75R16 version isn't rated high enough,
neoxerox
Re: Offroad tyres
Postby axam102 » Sun Feb 25, 2018 10:48 pm
Thanks for that mate, they look like they will do the job. how do you find them in the muck? not bad price either
axam102
Re: Offroad tyres
Postby neoxerox » Sat Mar 03, 2018 3:58 am
Great in the snow but I did still get stuck in saturated grass turning very quickly to slick mud.
Trying to reverse out (BTCS not functioning) one rear would just spin without touching the throttle. Not much weight in the back & fronts had sunk overnight. Reckon I may have gotten out if I'd let them down, but no pump/compressor at the time so a tow out from the farmer was the easier option...
Still glad i've fitted them.
M/T over A/T if you are in the mud often. Saw a sprinter 4x4 with those fitted, looked great!
neoxerox
Re: Offroad tyres
Postby wojciech » Sat Mar 03, 2018 1:00 pm
axam102 wrote:any good recommendations for off road tires with the correct weight rating?
Also:
Federal Couragia 225/75 R16 115/112 Q POR
Hankook RT03 225/75 R16 115/112 Q BSW, MFS
BFGoodrich Mud Terrain T/A KM2 225/75 R16 110 Q RWL
BFGoodrich Mud Terrain T/A KM 225/75 R16 110 Q
Kumho Road Venture MT51 225/75 R16 115 Q POR
And some more (Nokian Rockproof 225/75R16 115Q)
wojciech
