Compatible BCM for Mk7 12 seater
Re: Compatible BCM for Mk7 12 seater
Postby knobby1 » Thu Mar 08, 2018 3:12 am
Ewan from Oz wrote:
knobby1 wrote:
You "should" be able to do it with "Forscan" and a suitable ELM327 unit....cheap as chips. Forscan is Free to download too.
I have a couple of those cheap ELM327 type units but from reading various threads on this forum I thought only the VCMII interface could do programming. Anyway, I ordered one a week ago and am waiting for it to arrive. I might need a bit of a tutorial on how to do it with Forscan.
The VCM-II won't work with Forscan...it will only work with IDS...sometimes, and only then if you're extremely lucky to get one which actually works. Did you order the SP-177-C1 unit..??
I've used an ELM327 with Forscan and they do indeed do module programming, key programming, speed limiter etc, it also does all the normal pump and injector learns etc...
This one does the job nicely..
https://www.ebay.com.au/itm/AU-USB-OBD2 ... Swj3ZZjBKY
Postby Ewan from Oz » Thu Mar 08, 2018 3:20 am
Thanks for the eBay link. The devices I have are the bluetooth code reading devices.
This is the VDS unit I ordered. I should've asked the question on this forum before ordering it. Could've saved the money.
https://www.ebay.com.au/itm/2017-VCM-II ... 3299812328
Ewan from Oz
Postby knobby1 » Thu Mar 08, 2018 7:24 pm
Ewan from Oz wrote:Thanks for the eBay link. The devices I have are the bluetooth code reading devices.
You can get the "Modified" ELM327 which can do WiFi and/or Bluetooth but I find them a bit "flakey"....a proper USB cable connection is always better IMHO.
That VCM unit will possibly work for doing the basics but when it comes to module programming you may struggle a bit. We've had mixed luck with even the best of the "cloned" units.
Forscan can be had here:
http://forscan.org/download.html
A little light reading for you:
viewtopic.php?f=5&t=155150
Postby Ewan from Oz » Thu Mar 08, 2018 11:49 pm
Thanks. When I source a replacement BCM I'll post back here on my progress.
Ewan from Oz
Postby Ewan from Oz » Fri Mar 09, 2018 3:07 am
grogan197 wrote:There's a module reset option in ForScan. Not sure if that could sort your existing BCM but could be worth a shot. Forscan is free software, you just need a compatible ELM327 off ebay / amazon for about £15
Knobby, what do think about this option suggested by grogan? Is it worth a try before I buy another BCM?
Ewan from Oz
Postby knobby1 » Fri Mar 09, 2018 3:15 am
Certainly is worth a go mate, nothing to loose to try anyway.... he's no idiot. If it works great... if not, you'll just need to battle on.
Postby henk_t4 » Sat Mar 17, 2018 5:55 pm
please let me know I just ordered the elm327. I put a relay in between one off the two + wires to the bcm, so the only problem I have is that when the engine runs idle and the air-compressor starts the alarm lights come on (I have full airsuspension and air brakes on trailer
Verstuurd vanaf mijn SM-N910F met Tapatalk
henk_t4
Postby henk_t4 » Sun Mar 18, 2018 1:42 pm
I thought it was + and - on the bcm connector but they are both + . Which wire is the - on the bcm ?
henk_t4
Postby loot » Sun Mar 18, 2018 4:31 pm
Can you clarify what you mean?
There won't be a minus- at the bcm it'll be a chassis ground I'm sure but remind me what you are looking at and I'll look
Ids map here
loot
Postby henk_t4 » Sun Mar 18, 2018 5:54 pm
yes, where is the chassis ground(-) connected to the bcm?
henk_t4
Postby loot » Sun Mar 18, 2018 7:17 pm
I'm going to guess that you mean the actual main power connector on the bcm yes? It's simple if that is correct Lol.
Bcm.
Power ground 1 is c2 pin 29
Power ground 2 is c2 pin 32
Ground is c2 pin 3
All coloured black/yellow.
The ground loops are located at gp13 A and B
They should be in bemm which can be downloaded from Ford etis but it is currently down at the moment :-(
Ids map here
loot
Postby henk_t4 » Sun Mar 25, 2018 4:05 pm
loot wrote:I'm going to guess that you mean the actual main power connector on the bcm yes? It's simple if that is correct Lol.
Bcm.
Ground is c2 pin 3
my elm327 arrived and this is the result:
henk_t4
Postby loot » Sun Mar 25, 2018 4:16 pm
Clear them then read them again to see what stays
Ids map here
loot
Postby henk_t4 » Sun Mar 25, 2018 5:07 pm
loot wrote:Clear them then read them again to see what stays
the following are staying
henk_t4
Postby henk_t4 » Sun Mar 25, 2018 5:13 pm
I will buy some brake fluid tomorrow for the b1048
henk_t4
