Have just replaced the green o-rings on the injector leak-off pipe. It was fiddly to get the o-rings on to the pipe, but all 4 went on ok. I used a bit of white grease to ease them on.
When I went to reattach the pipes, they didn't want to clip back into the injectors so I gave them a tap with a rubber mallet.
Now I have noticed that the o-rings are squashed up and slightly visible with the pipe reattached, one of them has also pinched and a frayed bit is protruding. Basically it looks a bit of a mess and I think it is unlikely to be air-tight.
I'm sure I ordered the correct part (albeit from an ebay seller with positive feedback for these o-rings), but the new o-rings had a smaller centre hole and a wider cross-section than the old ones. I put that down to the old o-rings having been stretched. The new ones seemed the same when they were attached to the pipe.
What's the correct procedure for replacing these o-rings and reconnecting the pipes?
Should I have first placed the o-ring in the injector and then pushed in the pipe?
