Ok have you tried this
viewtopic.php?f=18&t=168536&hilit=Reconfigure+rcmHave you programmed the bcm with your asbuilt?
You must install the bcm and initialize it and pats for keys and asbuilt with your vin.
That's a blind install I don't recall doing a new module installation inhales from the old 1 into the new 1 and also sends asbuilt across. Rule is generally we expect that to also send a fault across if the original module is faulty but then I'd expect a checksums error or failure to program although there are multiple levels of data so...... Meh Lol.
Anyway.
Did you do asbuilt? Can you confirm that the bcm config is correct?
That's before you try reprogramming the rcm etc.
56 350 2.2 130ps mk7 with 2 side doors
65 290 2.2 125ps custom with 2 side doors
Ids v86 licence + v86.04 update + xprog
hereIds map
here
