grogan197 wrote:You need it to be removed with Ford software called IDS. A Ford garage, good independent or some forum members would be able to do this for you.
knobby1 wrote:grogan197 wrote:You need it to be removed with Ford software called IDS. A Ford garage, good independent or some forum members would be able to do this for you.
Forscan with an ELM327 can do it also..!!
grant11 wrote:rang ford they said sometimes the restrictor is hard wired into the brain of the van and unable to be removed is this true? he said they may do it and it wont work!?
grogan197 wrote:That's useful to know. Last I heard you couldn't do it in Forscan yet as it couldn't write to the PCM
grant11 wrote:thanks everyone for the replies but they may as well be in a foreign language as i am not mechanically minded in any way so dont understand at all its just a normal transit not a mini bus
grant11 wrote:im in kent about 15 mins from maidstone
