bambi mk 1 wrote:Overit8 wrote:grogan197 wrote:Does the LED on the dash stay flashing when you turn the key in the ignition?[/quote
No the light when I turn the key in ignition turns solid red and stays that way for about 40 seconds then starts to flash
sorry I took so long to answer
You have an imobilizer and or key problem as the red light should go out You need to get the codes read
Hi bambi mk 1 thanks can I use one of the OBD scanner that grogan197 sent the link for I have a Vgate Scan but i don't know if it good enough
I don't know who could read the codes read
