Overit8 wrote:Hi chris72a Yes I have checked the earth all seems good the dash lights come on the radio turns on
when I tryed the lights a alarm sounds under the dash and lights won't work only have one battery which is new I live in Hervey Bay Qld. Also sorry to take so long to answer you couldn't find the post
Overit8 wrote:Yes it has TDCi badge on the grill and 135 on the door trim this is my first Diesel Ford
knobby1 wrote:Overit8 wrote:Yes it has TDCi badge on the grill and 135 on the door trim this is my first Diesel Ford
All your starting issues could just be a duff ignition switch..!! A well known problem with some trannys.
Ah a TDCi....that means it's the "Son of Satan"...The Mk6 TDCi machines are well known to be "temperamental" at best...They're also well known for killing injectors and fuel pumps...
Might pay to get a new fuel filter, pop the old fuel filter off and cut if open to see if there's any metal swarf in there.
Our Ned will be along later to fill you in further..! He's in the UK so he's probably asleep as we speak..!
Overit8 wrote:grogan197 wrote:Does the LED on the dash stay flashing when you turn the key in the ignition?[/quote
No the light when I turn the key in ignition turns solid red and stays that way for about 40 seconds then starts to flash
sorry I took so long to answer
