Mk6 fwd tddi. Having a disco today on the dash. Bumps were putting coil light on and cutting out.
Never seen so many codes in my life on a single vehicle.
Pump comms, pats comms, pump watchdog, EGR etc etc.
One that stood out is pcm main relay.
So it looks like I have a loose connection and the rest of codes are triggered by power cut. Sounds right if I wemt slow and avoided bumps it worked fine for longer.
Battery is new a fortnight ago.
Checked battery leads also checked the main powerleads under bonnet. None were corroded or loose.
Any ideas where else to try?
Is ignition switch funny on mk6 or only mk7?
