knobby1 wrote:Altransit wrote:Could this be a faulty clutch switch
Good thought...but I thought it restricted the rpm to 3000 not 2000...??
Ah OK, 'twas just a thought
knobby1 wrote:Peewak wrote:In or out of gear won't rev past 2000rpm
Fuel filter after it started doing it wots a vcm
Being a 62 plate 2.2....Is it a Euro-IV or Euro-V machine??
Do you have any EML lights on the dash..??
VCM-II is what we use to connect our Transits to Ford's IDS, IDS is basically their diagnostic/testing/programming software....it allows us to do our own diagnostic, testing and programming work at home instead of being bent over & raped by a Ford dealer..!
Unplug temp sensor on fuel pump temporarily & see if that helps.Peewak wrote:No eml lights on and it's a euro 5
Peewak wrote:If so wot is the correct pressure the pump should throw out and also the vapourizer is reading a 1000 degrees
Users browsing this forum: Google Adsense [Bot], straydog
