Mk7 EGR and Manifold removal & clean
Postby Federalul » Sun Mar 18, 2018 11:04 pm
Hi folks, newbie here, got a 2010 mk7 transit 2.2 85bhp..
a few weeks ago the engine light management came on, maf sensor related code. Changed the maf sensor and deleted the error but the light (error) came back after a few miles.after reading a few threads on this forum now I’m planning to take off the egr & manifold and give them a clean (change the glow plugs while I’m there) but being a newbie I was wondering if anyone has done it allready or if there’s any “how to” thread you could point me to (couldn’t find anything myself)?
Federalul
Re: Mk7 EGR and Manifold removal & clean
Postby Federalul » Sat Mar 24, 2018 7:45 pm
anyone?!?
Federalul
Postby dibbdabb » Sat Mar 24, 2018 9:24 pm
Mine turned out to be a split intercooler hose.
Mk7 2013 260 125ps Limited - Panther Black Metallic 8)
dibbdabb
Postby Federalul » Sat Mar 24, 2018 9:37 pm
I get p1103 error so there must be either egr clogged or maf sensor wiring fault as maf sensor has just been changed (error deleted) but it comes back after a few miles..
Federalul
Postby knobby1 » Sun Mar 25, 2018 8:02 pm
Federalul wrote:I get p1103 error so there must be either egr clogged or maf sensor wiring fault as maf sensor has just been changed (error deleted) but it comes back after a few miles..
MAF or MAP sensors rarely fail. It's usually a result of a duff EGR or split boost pipe.
Postby johnkels » Sun Mar 25, 2018 11:34 pm
I don't seem to be able to find information on how to take out the EGR valve on my mk 7 2.4 rwd is it possible to remove as i cant even seem to get to the bolts help please
johnkels
Postby knobby1 » Mon Mar 26, 2018 12:48 am
johnkels wrote:I don't seem to be able to find information on how to take out the EGR valve on my mk 7 2.4 rwd is it possible to remove as i cant even seem to get to the bolts help please
It's best/easier to remove the inlet manifold first, you'll probably need to clean the manifold out anyway, (it'll be full horrible of oily spooge).... two of the EGR bolts can then be removed from the top, the other two can be "got at" from underneath the van...trouble is, in the UK they corrode horribly and almost always are near impossible to get out without grief....they either round off or snap off.. :(
Postby johnkels » Mon Mar 26, 2018 6:07 pm
dosen:t sound to good so could mean engine out ? is it safe to put heat on the bolts. Did think of cutting out the old EGR and fitting a new one or blanking off both ends of whatever is there.
johnkels
Postby knobby1 » Mon Mar 26, 2018 8:22 pm
johnkels wrote:dosen:t sound to good so could mean engine out ? is it safe to put heat on the bolts. Did think of cutting out the old EGR and fitting a new one or blanking off both ends of whatever is there.
You're going a bit overboard to remove the engine just to replace the EGR....just pull the inlet manifold off, makes things a lot easier.
You're also wasting your time removing the EGR and/or blanking it off, it will fail at MOT time as of May 20th...they'll be checking for fitment and operation after this date....big fines apply if found with non working or non existent EGR valves.
Postby johnkels » Mon Mar 26, 2018 9:31 pm
Yes thanks for that. will have another look at things tomorrow. Thanks again
johnkels
