Gordk wrote:I’ve had a quick read, is there anyone close to Sheffield that has the software to do the update? Or even do the job? Thanks for your reply
grogan197 wrote:Unless you get the software update any repair will ultimately fail, it shouldn't cost much to get the update and learns done as it's tops an hours work. The update usually fixes the problem without a need to replace the SCV or PRV.
Ml Autos wrote:Software update can also fix scratches inside the valve!
Ml Autos wrote:Oh didn't you know that?;) according to grogan197, software update is the key to fix hunting at idle problems.
I personally use software update to pump the tyre
