Doors rubbing arches....
Postby gavcarter » Tue Mar 20, 2018 12:16 am
As title.
Van had LOTS of welding last year.
Noticed the doors have scraped paint of the very tops of the wheel arches.
Door seems to drop a fair bit as its opening but it shuts first time everytime, it doesn't need lifting to close it....
Does this sound normal ( the dropping not the touching)
gavcarter
Re: Doors rubbing arches....
Postby loot » Fri Mar 23, 2018 11:02 am
Measure the gaps all of the way around, check if they've welded the arches but on top of the old ones or they've taken up space that should have not been taken up.
Is it catching at the front or the back? You can adjust the hinges and the door jam a little bit to get clearance.
It's mostly trial and error though.
Extreme case is move the joor jam up a bit and lift the door up by a bit of force.
The latch would locate against the jam to a point without fowling.
Ids map here
loot
Postby gavcarter » Mon Mar 26, 2018 9:16 am
loot wrote:Measure the gaps all of the way around, check if they've welded the arches but on top of the old ones or they've taken up space that should have not been taken up.
I did the welding.
The arches where full replacements.
Afaik the door is as high up as I can get it. There's no adjustment left on the hinges lol
Will have another look at some point though.
The part that catches is the front corner of door just behind the wing.
There is a 5_6mm gap when shut. When opened it catches the door.
gavcarter
Postby DAZZ » Mon Mar 26, 2018 3:20 pm
Mines doing it too, only on drivers side when door fully opened, when closed gaps consistent all way round, its never been welded or had arches, I suspected the hinge pin to be worn, but was waiting for warmer weather before I investigate
2008 mk7 280 85 Crew cab - poverty spec :lol:
Replaced with......... a 300c estate :lol:
now sold, the judder did me ed' in :lol:
suppose my 350z and hayabusa will have to do for now :twisted:
DAZZ
Postby ned » Mon Mar 26, 2018 7:44 pm
My drivers door is the same, its like it drops when opened fully, bloody ford. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby bambi mk 1 » Mon Mar 26, 2018 7:53 pm
ned wrote:My drivers door is the same, its like it drops when opened fully, bloody ford. N
You need to step out like a Lady, not like an old man leaning on the door.
bambi mk 1
Postby ned » Mon Mar 26, 2018 8:00 pm
:shock: have you been spying on my :lol: :lol: N
ned
Postby dirtydog » Mon Mar 26, 2018 9:13 pm
dirtydog
Postby knobby1 » Mon Mar 26, 2018 9:14 pm
ned wrote: :shock: have you been spying on my :lol: :lol: N
And please don't pull your skirt up when alighting your vehicle... :shock:
Postby dirtydog » Mon Mar 26, 2018 10:05 pm
He does that on purpose you know :shock:
dirtydog
Postby ned » Mon Mar 26, 2018 10:20 pm
I only wear mini skirts :wink: goes well with the cowboy boots :lol: N
ned
Postby knobby1 » Mon Mar 26, 2018 11:48 pm
ned wrote:I only wear mini skirts :wink: goes well with the cowboy boots :lol: N
I hope there's a pair of "fishnets" in there somewhere...if not you can borrow mine ...or BJT's...he's got some pink ones with sequins on..! :wink: :mrgreen:
Users browsing this forum: Google [Bot], Google Adsense [Bot], Majestic-12 [Bot]
