CasualNerd wrote:I could just block it off, but I guess then the interior lights won't work when I open the door, and it should have been an easy fix.
(Assuming that leaving it disconnected tricks it into thinking the door is closed, otherwise it will be a problem)
ake wrote:Of the two wires on the old switch, one is just an earth wire. You can leave this disconnected
