problems when it rains
transit has broken down again
Postby george999 » Sat Mar 17, 2018 6:25 pm
she's just had a new crankshaft sensor and new cam sensor and new flywheel and batteries.went into limp mode.she fired up with easy start .but would not rev she would idle ok but not rev.rac came out and said it's low pressure valve on top of fuel rail.had her running on and off while waiting for recovery and now she won't start.
it's a jumbo transit 09 plate 2.4
anyone got any idea of what is wrong
george999
Re: transit has broken down again
Postby karl » Sat Mar 17, 2018 8:05 pm
cam and crank sync :D
or injectors f***
karl
Tranny Lover!!!
Postby george999 » Sat Mar 17, 2018 11:06 pm
injectors were only done just over a year ago and the crank sensor and cam sensor were only done 2 weeks ago
george999
Postby bambi mk 1 » Sat Mar 17, 2018 11:17 pm
When was the fuel filter last changed :?: Did you check the indicator on the filter head :?:
bambi mk 1
Postby george999 » Mon Mar 19, 2018 8:52 pm
started her up earlier and she started fine but won't rev over 2000 rpm if I try to take her over that it's like a misfire and the ---- dashs flicker
george999
Postby Punto443 » Mon Mar 19, 2018 9:38 pm
Low fuel pressure! the rac mans already said!
Probably blown it’s prv!
Might need, scv,prv, pump&pilot learns, updates?
Probably best check the frp and do a leak off test.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby Ml Autos » Mon Mar 19, 2018 10:20 pm
Low fuel pressure and low tyre pressure are exact same untill we see the actuall reading of fuel pressure.
Precision guess work)))
What are the fault codes?
What is actuall fuel pressure?
Is tha air gap correct between the flywheel and the crankshaft position sensor?
Answer those and the van will start and run again
Regards
Ml Autos
Postby bambi mk 1 » Mon Mar 19, 2018 10:25 pm
Ml Autos wrote:Is tha air gap correct between the flywheel and the crankshaft position sensor?
Regards
I wonder is the new sensor tight :?: A loose sensor will cause the dash flicker :wink:
bambi mk 1
Postby Ml Autos » Mon Mar 19, 2018 10:35 pm
Dash flickers as rpm drop low :wink:
Ml Autos
Postby george999 » Tue Mar 20, 2018 7:25 pm
just started the transit up and she's running fine .the only thing I can think of is it gets damp when rains hard .
george999
Postby george999 » Wed Mar 21, 2018 1:36 pm
after all the trouble over the weekend , went to start her up and she runs fine , it seems everytime it rains it causes her to lose power and she has to be recovered something getting damp and causing a short ????
george999
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot]
