Hi guys!
First post here so please forgive my naivety, Im sure this must of been discussed a million or more times.....
Ok so I have a 2006, 2.0 diesel, FWD, SWB, 100 hp, Low roof last of the 6's
The accelerator pedal has started playing up, revving high then not responding at all etc etc. I'm sure it's knackered so I've removed it and found the part number on the back which is 1C119F836-AB, I've found the one that I want to buy as it is new old stock but the last two letters instead of being AB are AD. So my question is, what's the difference? Would this not be compatible with my van?
And, just to complicate matters I have replaced the pedal in the past with one from an older van. I cannot remember if the numbers were different from the original, the original May of ended in AD!
Hope that makes sense, any help very gratefully received guys
