caidsdad wrote:hello just got home parked up and unloaded, then went out to move the van and it wont turn over everything lights up go to start position and the milometer goes from numbers to dash's, anyone had this, and the glow plug light goes out in a second
caidsdad wrote:thanks for the reply yes 2.4 350 140 ps battery's full of charge its a new ignition a few weeks old, I've been told because of the milometer going from numbers to dash's to check the fuse's and relays in the fuse box under the bonnet so I will give that a go in the morning
caidsdad wrote:caidsdad wrote:It was the starter motor, just packed up stopped, what an awkward job to get the wire's off got it off in the vice jump lead's on and nothing solenoid not moving it was jammed solid and the motor just made a noise, never had that before just stopped
