CH1 wrote:Mk7 doesnt have a dpf light
Frag wrote:There a icon for it on cluster that you can make out,
BUT,it's not used and doesn't light up under any circumstance on any mk 7 I've ever seen.
If dpf gets blocked,it puts EML on initially,past a certain level and power train lamp will come on too.
There is no lamp to indicate a re-gen is in progress either.
(Whether that dpf indicator works in other countries I don't know,but deffo not on a U.K. Van)
It's only the latest pcm level,and cluster level mk8s that give a message for 'drive to clean' or Regen in progress
CH1 wrote:Frag wrote:There a icon for it on cluster that you can make out,
Thank you, Transit connect does have a light (someone correct me if I am wrong) but mk7 defo doesn't
