done my discs and pads a few years ago........
then a front bearing a year ago........
had to do bearing last night and ended up stripping the threads in the disc trying to remove the hub the usuall way, so had to get new discs etc again but only fitted one
looked at the price of pullers and they are around the £130 mark,
going to try and make one so i can change the other disc and stick in another bearing while im in there
thick piece of flat plate, with something like an m27 nut welded onto it, bolt this onto the rear where the drive shaft would go through and wind a m27 bolt through against another plate to push the hub off
