Altransit wrote:Don't you have two batteries
Check the front one
ARTCARCOM wrote:Yes two batteries
ARTCARCOM wrote:ARTCARCOM wrote:Yes two batteries
But would this cause no ignition lights as I checked batteries one was about 9 volts but did charge it but still thought there be enough to put ignition lights on as batteries been flat before but ignition lights come on
ARTCARCOM wrote:Hi just an update to the problem I was having . Well tried everything I could think of so took it to auto electrician few days later & £75 + vat running again it was a broken wire behind fuse box well worth the money only down side someone stole my sun visor while parked in the compound but that’s life hope this helps someone
