Scotchgitt wrote:Still not fixed.
1 question if the brake pad warning light is on does that cause the abs light to come on too?
I changed the sensor and discs and pads at the rear and now the error code for the abs is no longer stored but the light goes on on the dash as soon as I drive above 15mph. But no visible error code.
So I have fixed something
Yes i think you need headlamp out mate, I'm going to have a look at minr tomorrow as I've had same problem for a while now (also auto locking stopped worcking) but nearly had a wee bump yesterday skidding to a baw hair from impact due to no abstilly wrote:Any update from this, as I have exactly the same issue. No codes stored, but still both ABS and TC lights come on after driving a short distance.
Had IDS on the van last week, and it goes through the tests for ABS. Sometimes the ABS lights go out after the required few seconds, sometimes they just stay on. IDS reports it as failed to communicate with ABS module.
Where exactly is the connector plug for the ABS. I can find a big one in the front n/s of the van, near the fusebox, but not the one other people talk about. Do I need to remove the headlight to see it ?
Have you never kicked a fitbaw......football......bawbag.....pippin wrote:I have the same problem - ABS & TC warnings lit. Permanently.
Certainly needed ABS on some dodgy windy (and windy!) single track roads on the Isle of Mull last week.
So, following this thread with interest.
andz327 - what does "but nearly had a wee bump yesterday skidding to a baw hair from impact due to no abs" mean?
"baw hair" - new one on me.
