MK 7 - 2.2 - Oil Pump U/S (Pictures)
Postby HU92 » Thu Mar 29, 2018 11:05 pm
Spec:
Transit Mk7 - 2.2 - T350 - RWD (2012)
Hi all , (Can`t remember the log in details for the old account)
Van broke down yesterday , Thought i`d share a few pictures (Since we all like pictures)
She`s been rattling for a few weeks so i was thinking the chain / tensioner is on the way out (bought a complete kit ready)
As i had planned to strip it down this coming weekend but it started rattling bad and cut out yesterday.
Restarted and has compression but sounded really bad. Killed it off and got towed back
Stripped the front off this morning and found the oil pump chain loose / no tension at all ,
This has caused the chain to grind into the casting and worn the teeth completely off the sprocket. (Is this common?)
I`m hoping with a new pump , chain + tensioner (+ a several oil filters + changes) She might be okay.
I need to get the sump off next , cross bar looks a bugger!
She may /has been starved of oil if the chains been skipping , I might be very lucky :cry:
HU92
Re: MK 7 - 2.2 - Oil Pump U/S (Pictures)
Postby karl » Thu Mar 29, 2018 11:30 pm
to me its lack of oil changes also the lack know how for these engines :(
karl
Tranny Lover!!!
Postby paul2012 » Fri Mar 30, 2018 12:27 am
I would be looking at big end, mains shells & pistons too.
Here's what damage looks like with failed oil pump.
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby HU92 » Sat Mar 31, 2018 7:10 pm
Cheers
Got the sump + pump off today ,
The oil pump tensioner is just plastic :roll: (Bad design that)
Picked the other bits of the tensioner out the sump
Just waiting for parts now / and I can test her.
Stripped a 2.4 , 90PS engine out of curiosity / see if parts were the same
It`s has an oil tensioner for the oil pump chain. (Different)
HU92
Postby karl » Sat Mar 31, 2018 7:49 pm
I have always liked the old style one
but these days you dont get that and this was only avaliable for the early engines :(
karl
Tranny Lover!!!
Postby HU92 » Tue Apr 10, 2018 11:03 pm
Cheers Karl , The old style looks a lot better eh
Is the mk7 2.4`s also using that plastic crap?
Well it was a rookie mistake on my part today..
Had the airgun on the fuel pump sprocket anti-clockwise trying to loosen it
People reading this in the future..
NOTE: It`s Clockwise to Loosen / Anti-Clockwise to Tighten
Set up a puller and ended up bending the bolt :oops:
The pulley was on the taper solid #airgun
Drilled a hole in the head of the bolt (Keep it centred)
and used the puller again , This split a chunk off it off
Another grab managed to free it - Lesson learnt.
New bolt from Ford was £3 ish (In stock)
HU92
Postby karl » Sat Apr 21, 2018 10:40 pm
:shock: :shock:
well I have never had to do that before
karl
Tranny Lover!!!
Postby HU92 » Sun May 06, 2018 10:03 pm
Ay the air gun on a taper was the cause there.
It`s all rebuild but chapping :? , Tried to upload a 5 sec vid but no joy.
Plugged her into the modified elm tonight and reset all the learned data (for the crack)
I`ve ordered a used engine from London so hoping it will be alrite.
Case of coding in my injectors using the mod elm?
Can`t get the new ids 3 to connect at all
I`ll make a new thread about that tho.
HU92
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot]
