Altransit wrote:Well.......................... you know where the motor was, that was such a barsteward to get out It's inside that casing
v8dave wrote:Silly question, have you checked the heater intake duct from the bonnet to the bulkhead ?
richgold wrote:A good thing to check is if you put your heaters on the windescreen after warming the van up to temp and check for slight misting of the windscreen. If your matrix is gone then when its full of hot water it will be coming out as steam which should settle on your screen when in use.
tyasstark wrote:v8dave wrote:Silly question, have you checked the heater intake duct from the bonnet to the bulkhead ?
No I haven't. Silly answer. What does that look like lol
tyasstark wrote:Ok so this morning on the way to work it started smoking from under near the exhaust. Mechanic says it a honeycomb unit on top of the gearbox ?
Users browsing this forum: Google [Bot], knobby1
