Ecu change ?
Ecu change ?
Postby Newguy33 » Tue Apr 10, 2018 2:28 pm
Hi there , I think I may need to change the ecu on my 06 tddi transit , is this a big job ?
Thanks for any help
Newguy33
Re: Ecu change ?
Postby knobby1 » Tue Apr 10, 2018 8:51 pm
Newguy33 wrote:Hi there , I think I may need to change the ecu on my 06 tddi transit , is this a big job ? Thanks for any help
Why..?? What's it doing...or not doing..??
Re: Ecu change ?
Postby Newguy33 » Wed Apr 11, 2018 12:37 pm
Hi
The coil is flashing, it’s starting to have trouble starting (odd sentence ) , black smoke when exclerating, poor throttle response.
Diesel mechanic who fitted pump thinks it could be the ecu .
Any thoughts ?
Newguy33
Re: Ecu change ?
Postby Newguy33 » Wed Apr 11, 2018 2:32 pm
Newguy33
Re: Ecu change ?
Postby v8dave » Wed Apr 11, 2018 6:15 pm
Is it a front wheel drive ?
If it is then it's probably a wiring loom issue, where the loom goes past the starter motor.
That said P1664 could be your fuel pump electronics failing.
v8dave
Re: Ecu change ?
Postby paul2012 » Wed Apr 11, 2018 6:27 pm
Take it some one whom knows what hes doing. Your Diesel Mechanic is a wanabe mech
P0409 Exhaust Gas Recirculation Sensor "A" Circuit
- Can result in MIL flashing (Glow plug light on Transit mk6's)
P1563 Injection Pump Control Module Requesting Engine Stop
P1664 Injection Pump Control Module Malfunction
Is for a Failing/Failed fuel pump :!: - These 2 DTC's should have been cleared when replacment pump was fitted
A wiring fault to fuel pump often results in DTC
P1665 Injection Pump Control Module Communications
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Re: Ecu change ?
Postby Newguy33 » Wed Apr 11, 2018 8:24 pm
Yeah it’s fwd,
I’ll have a search for someone in Swansea , but I’ve been searching for a while for a mech who lnkws what there doing.
The new pump cost £550 from pfjones .
Thanks for the replies
Newguy33
Re: Ecu change ?
Postby Dan T » Fri Apr 13, 2018 10:20 pm
Newguy33 wrote:Yeah it’s fwd,
I fitted a pump a few months ago that was supplied to my customer by PF Jones. It was faulty and although it started, there was a big diesel knock... so there’s always a chance it’s faulty
Dan T
Re: Ecu change ?
Postby Newguy33 » Sat Apr 14, 2018 9:39 pm
I know , annoyingly that’s why the wife wants to get rid of the van.
I’ve taken it to a garage , they think the egr valve is the first place to look and then Check the wiring .
I used some egr cleaner today and it nearly has cleared all the black soot . The van is running like a beast . Although slight rattle on start up .
On the pump you fitted , where there any issues other than the pump ? Anything leading it to fail ?
Also did the fault codes come back ? My fault codes have gone now .
Thanks for replying
Newguy33
Re: Ecu change ?
Postby Newguy33 » Mon Apr 16, 2018 11:21 pm
The garage is doing the egr this week. £180 with 1 year parts and labour warranty .
Fingers bloody crossed
Newguy33
Re: Ecu change ?
Postby Newguy33 » Tue Apr 17, 2018 7:26 pm
Hi ,
Bloody van , back smoke all day and crazy rattling noise when accelerating. Once it gets through it it drives fine .
P0404 codes is up 3 times in a row.
Not safe to drive absolute nightmare
Newguy33
Re: Ecu change ?
Postby Newguy33 » Tue Apr 17, 2018 7:33 pm
Newguy33
Re: Ecu change ?
Postby Dan T » Sat Apr 21, 2018 8:29 pm
There’s n9 sound on that video.
Tbh I could have said that a new egr was a waste of time and money, a simple blanking plate would rule an6 mechanical faults out. Then as Paul said already, wiring faults will flash the mil light.
I’d be reasonably confident the supplied pump you have is faulty.
My one came in not running and once the new pump was fitted it was spitting out pump timing codes.
Dan T
Re: Ecu change ?
Postby Newguy33 » Sun Apr 22, 2018 9:29 am
Hi , I’ve no ide why sound isn’t g working . Egr change Has been done, and your right does feel like a waste of time .
However I could drive it , I took it for a 60 mile drive to try and burn out the black smoke. Which has sort of worked .
But I’ll be phoning garage again , as they said there was no sign of black smoke . And this is how it drove 2 mins after collecting van
https://youtu.be/Li2C_QlG0yg
It doesn’t feel as response as my first pump change , for the 3 months of my first pump change ( from eBay ) the van drove like a beast , more responsive than my new transit Work van:
Newguy33
Re: Ecu change ?
Postby paul2012 » Sun Apr 22, 2018 1:12 pm
2.0 TDDI 100ps.
Has vac solenoid for EGR valve been checked/replaced :?:
It bolted to inlet manifold.
Disconnect vac to to EGR valve & see if any improvement.
paul2012
