Hi All
I removed the speed limit on my MK7 2.4 using forscan and now my power train light is on.
Prior to removing the speed limit I had the EGR blanked and deleted some time ago, would removing the speed limit have overwritten the EGR delete from the ECU?
In addition the red immobiliser light flashed rapidly for quite some time, then moved to blinking approx 3 times every few seconds and has now stopped blinking. At one stage during this process the airbag light came on too but this has now gone out.
I've checked the DTC's and there is not one for the EGR but there is one for the powertrain:
===PCM DTC U2101:00-2F===
Code: U2101 - Control Module Configuration Incompatible
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
===END PCM DTC U2101:00-2F===
===PCM DTC U0140:00-28===
Code: U0140 - Lost Communication With Body Control Module
Status:
- Previously Set DTC - Not Present at Time of Request
===END PCM DTC U0140:00-28===
===PCM DTC P0704:64-28===
Code: P0704 - Clutch Switch Input Circuit
Additional Fault Symptom:
- Signal Plausibility Failure
Status:
===END PCM DTC P0704:64-28===
===PCM DTC P2265:64-28===
Code: P2265 - Water in Fuel Sensor Circuit Range/Performance
Status:
