Idle problems. No revs. Please Help
Postby Bizz666 » Fri Apr 20, 2018 10:00 pm
I brought a 2006 Transit 2.0 the other day after covering a mear 8.9 miles in it i lost power while driving so i pulled straight over turned it of and fired it back up. It now sounds really lumpy and it doesn't rev at all.
The guy i brought it off said it would be air in the fuel system and came round and bled it however no joy.
He now reckons it is the accelerator pedal and says he will come and fit one for me tomorrow.
How likely is it that the pedal is at fault?
Thanks in advance
Bizz666
Re: Idle problems. No revs. Please Help
Postby ned » Fri Apr 20, 2018 10:29 pm
Your best getting the codes read so the van can tell you what's wrong, a 2.0L will be a mk6 is it a 125 tdci or a tddi? If unsure tell us the reg no and we can find out for you. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Bizz666 » Fri Apr 20, 2018 10:38 pm
I'm not sure i know its the 85bhp one. Reg is LB55 VDX
The RAC plugged it in and nothing came up. They just towed me home.
Bizz666
Postby ned » Fri Apr 20, 2018 10:46 pm
Bizz666 wrote:I'm not sure i know its the 85bhp one. Reg is LB55 VDX
Transit 2000-2006, 2.0L Duratorq DI (85PS), Diamond White 73
VIN Number: WF0VXXBDFV5E86931
Registration Number: LB55VDX
First Registration Date: 24.01.2006
Registration Country: GB
Primary Features
Build Date: 07.12.2005
Vehicle Line: Transit 2000-2006
Cab Style: Regular Cargo Van LCF
Series: 260S Series
Engine: 2.0L Duratorq DI (85PS)
Transmission: 5-Speed Manual Transaxle - VXT75
Drive: RHD FWD
Axle Ratio: 4.54
Emission: Light Duty Truck Stage III
Territory: (+)"GB"
Paint: Diamond White 73
Interior Colour: Dark Graphite
Interior Fabric: Stylize (-G-C)
Minor Features
With Low Roof
Full Partition/Fixed Glass Window
LH Sliding Side Cargo Door - Low
With Hinged Rear Loading Doors
Southampton Plant Built
Less SVO Application/Label
Marketing Level 3
Less 2nd Row LH Side Window
With Rear Blanking Panel
Less Heated Rear Window
Less Header Mounted Package Tray
With MDF Complete Rear Trim Board
Flr Cvr-Rubber Ins-Extended
With Partial Headlining - Moulded
With Roof Height Feature Pack 1
With Door Map Pocket
With Front Roof Grab Handle
With Load Space Tie Down Loop
With Moulded Board Trim
Drivers Door Trim - Level 2
Passenger Door Trim - Level 1
Less Rear View Mirror
Large Head/Short Arm Mirror
Passenger Lrg Head/Short Arm Mirror
With Drivers Seat Fixed Armrest
Less Passenger Seat Armrests
Less Passenger Seat Valance
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
Less 2nd Row Rear Seat
With Driver 6 Way Mnl.Seat Adjuster
Less Adjustable Passenger Seat
With Door Dead Locks
With Door Entry Remote Control Unit
Less Rear Window Wiper/Washer
With Driver Air Bag
With Spare Tyre Security Package
195/70R 15C LI 100/98 BSW
Any Brand Tyre Vendor
Less Engine RPM Control
Cold Start Up To -20%c
4 Wheel Anti-Lock Braking System
With Brake Only Traction Control
With Sngle.L/B Dvr/Dual L/B Pass.St
With Manual Clutch
Less Rear Seat Climate Control
With Recirculating Heater
Less Rear Compartment Heating
With MPH/KMH Speedometer
With Radio Pre-Equipment Pack 1
4000 Series
With Load Compartment Lamp
Less High Mounted Stop Lamp
With Front Headlamp Levelling
Mk6 are not obd2 compliant so the rac code reader may not have been able to read the codes, you're vans a TDDI. N
ned
Postby Bizz666 » Fri Apr 20, 2018 10:51 pm
Wow thats a lot of info.
What kind of reader do i need?
Bizz666
Postby ned » Fri Apr 20, 2018 10:59 pm
Eml327 ford, mazda, Lincoln and download forscan for free (readers are about 15 sovs) f-super (again around 15 sovs) or ids (vcm2 clone of fords diagnostic equipment) :P
If the seller is willing to fit a throttle pedal for free then let him and see if it works :wink: N
ned
Postby Bizz666 » Fri Apr 20, 2018 11:23 pm
Ok thank you for all your help. Will see how it goes tomorrow and if not will try get a reader sorted.
Bizz666
Postby ned » Fri Apr 20, 2018 11:26 pm
Keep us informed how you get on, it's worth getting a reader as they come in handy and are cheaper then getting the van plugged in at a garage. N
ned
Postby Bizz666 » Sat Apr 21, 2018 8:17 pm
Not turned up he cant find it. Cant say im surprised. My patience is wearing thin now.
Anyone local to Notts thats got a pedal i can buy cheap or one i could try?
I dont think for 1 min the pedal will fix it but who knows.
Any other ideas?
Bizz666
Postby JimmyBob » Sat Apr 28, 2018 4:18 pm
any joy mate? im having the same symptoms tried cleaning the egr valve my code reader says theres no faults but ive seen someone mention theres a differnt code reader for the transits anyone have a link where to bu one ?
cheers and hope you dont mid me posting on your thread
JimmyBob
