Mk7 key coding
Mk7 key coding
Postby Thequeenscheese » Sun Apr 22, 2018 6:55 pm
Considering I've managed to cock one of my fobs up ( repairing my flip key conversion I managed to get superglue on 2 of the buttons on the pcb :? Doh) anyway if I buy another new key can it be coded with 2 working fobs or is it Ids only? (My pcb still works but 2 of the buttons are destroyed enough not to work in a housing ) ..
Cheers
2.2 tdci T280
Thequeenscheese
Re: Mk7 key coding
Postby dirtydog » Sun Apr 22, 2018 7:16 pm
I'm pretty sure it's ids only for the mk7
dirtydog
Re: Mk7 key coding
Postby blue estate » Sun Apr 22, 2018 7:26 pm
dirtydog wrote:I'm pretty sure it's ids only for the mk7
100% right :wink:
72plt MG 5 ev estate Battery car
blue estate
Re: Mk7 key coding
Postby Thequeenscheese » Sun Apr 22, 2018 8:35 pm
Thought so, I have seen some switches on eBay for about £10 with new blue case and battery prob opt for that tbh they should be easy enough to solder in.., all this because no one seems to make an official mk7 flip housing I know I'm banging on about it in a few threads but I really don't get why there isn't one about odd how some vehicles get overlooked for them and I've copped for 2 of them lol my old navara didn't but luckily the almera of the same era was an easy mid to get to fit, and then there's the transit ffs ha the earlier fiesta one is almost an easy mod, I had it working but then part of the mod failed and I was trying to do a better job using glue and cocked the switches up tut, I'm almost tempted to get a prototype cnc'd or printed off dos there has to be a market for them with so many mk7s about, plus some of the cars must be the same key surely..
2.2 tdci T280
Thequeenscheese
Re: Mk7 key coding
Postby Airthies » Sun Apr 22, 2018 10:50 pm
100% right :wink:
Can code keys with foreskin and an mongled elm327 as long as you register on the site. it even does in and out codes for you
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Re: Mk7 key coding
Postby davyjcb » Sun Apr 22, 2018 11:01 pm
+1 for forscan have done dozens of mk 7s even the later ones with dpfs although haven't tried any customs or mk8s
96 escort 55 van gone
98 smiley mwb semi high gone
01 90/350 mwb semi high roof gone
05 135/350 lwb semi high roof gone
10 85/260 swb low roof leader gone
09 140/350 lwb semi high fwd
11 115/330 mwb semi high roof
davyjcb
Re: Mk7 key coding
Postby Airthies » Sun Apr 22, 2018 11:06 pm
I got a key kit with batt case and buttons.
Unfortunately one of the buttons stoped working within about 48hrs.
You can get them other places like RS components or maybe maplin if you ca find one that's still got them.
V86+patch
V86.04
X-Prog
C81
Airthies
Re: Mk7 key coding
Postby davyjcb » Sun Apr 22, 2018 11:12 pm
And as a footnote I don't use an elm327 as the interface I use a pass-through device it does not need the can switch and will see all the modules at one time automatically picking which one it needs ,if you have an els327 or a mongoose or even a good vcm2 they will work first time every time
davyjcb
Re: Mk7 key coding
Postby HU92 » Sun Apr 22, 2018 11:15 pm
Slight off topic here..
Can a modified elm327 be used to code in a remapped ecu? (Mk6 , 2.4 , 90PS)
Old man had his camper remapped by vantuner then the fuel pump went a few months after (doh)
Changed the complete engine ect (kept the ecu)
He was asking if the "go go ecu" could be matched to the current engine.
It made a massive difference :D :lol:
I just bought in a elm327 and a vcm 3 is on order for my own vans issues.
HU92
Re: Mk7 key coding
Postby Airthies » Sun Apr 22, 2018 11:22 pm
HU92 wrote:Slight off topic here..
Better starting a new thread some time as helps when searching for issues too.
I'd guess it's just the pump that'd need virginising and recoding to the pcm on a mk6 but I've not had a lot to do with them . Some of the others may know better.
V86+patch
V86.04
X-Prog
C81
Airthies
Re: Mk7 key coding
Postby HU92 » Sun Apr 22, 2018 11:32 pm
Cheers Airthies
I`ll make a new thread , Don't want to wipe it altogether :oops: :lol:
HU92
