robrescue wrote:thanks for replies. yea oil looks fine. i think its just water getting into piston. Would egr cooler cause these symtoms.
also forgot to mention its hard starting. locks up like water is leaking into cylinder and causing a lock when starting.
would you try replacing egr cooler first?
robrescue wrote:So yeah. Bypassed egr cooler. Still pumping bubbles into header tank. Gotta be head gasket. Spose theres only one way to find out.
robrescue wrote:Hi. Its a 2.4l rwd. Only done 80k but been towing a lot lately so been haveing a hard time. Yes removed water pipes from each end of egr cooler behind cylinder head and joined together with a hydraulic fitting. Will be around 15mm yes. The egr on this one isnt water cooled as i know some are. Th ka
