Transit mk7 2.2 85bhp - black smoke under acceleration
Re: Transit mk7 2.2 85bhp - black smoke under acceleration
Postby daraioj » Mon Jun 11, 2018 9:13 pm
Karst wrote:I didn't get anything else done today. I was so done in I stayed in bed till the early afternoon.
I'm gonna try to post a photo of silver nitrate stains, but I have not had success with posting photos here lately. Seriously, I have washed and scrubbed the area, it is 100% stain.
:) it's not that bad!
It's like a negative of a vitiligo beard... You might even start a new fashion... You never know.
2010 2.4L RWD 100ps MT75 LWB High Roof
daraioj
Postby Karst » Mon Jun 11, 2018 11:00 pm
Oh well, thanks for saying so :wink:
I've just found out, I can wash it out with sodium cyanide!
Ford Transit Mk 7 Panel van, ex-posty's, 57 reg, 2007. Duratorq TDCI 2.2 (85PS)
Karst
Postby Karst » Tue Jun 12, 2018 8:11 am
Ahhhhhhhh..... Call me old fashioned, but I'm not suuurrre that's going to be a good thing to do, right by my mouth and everything
Karst
Postby daraioj » Tue Jun 12, 2018 8:17 am
Karst wrote:Ahhhhhhhh..... Call me old fashioned, but I'm not suuurrre that's going to be a good thing to do, right by my mouth and everything
Hmm not sure the WHO would recommend that...
"Sodium cyanide, like other soluble cyanide salts, is among the most rapidly acting of all known poisons. NaCN is a potent inhibitor of respiration, acting on mitochondrial cytochrome oxidase and hence blocking electron transport. This results in decreased oxidative metabolism and oxygen utilization. Lactic acidosis then occurs as a consequence of anaerobic metabolism. An oral dosage as small as 200–300 mg can be fatal."
daraioj
Postby Karst » Tue Jun 12, 2018 8:28 am
daraioj wrote:Hmm not sure the WHO would recommend that...
Cody on Cody's Lab YouTube channel. He demonstrated it on his own hand! In another video he actually drank a bit of very diluted cyanide to prove that we can cope with it in small amounts! I love that guy! :lol:
Karst
Postby Karst » Fri Jun 22, 2018 8:11 pm
Hey daraioj,
How are you doing?
I'm going to make another attempt with the van on Sunday. Have no idea what I'll start on yet. But that's the plan.
I had to make a pretty major adjustment to the drivers door last Sunday, didn't finish till 9pm. I might post it on "What did you do to your Transit today.
:wink:
Karst
Postby daraioj » Fri Jun 22, 2018 9:37 pm
Karst wrote:Hey daraioj,
How are you doing?
:wink:
I'm good! Thanks. Waiting for my SCV to arrive. Hopefully that'll stop the stupid hunting.
I'm planning on cleaning the inlet manifold while I'm at it... That'll be fun!
Keep us posted on your progress!
daraioj
Postby Karst » Sat Jun 23, 2018 8:58 am
daraioj wrote:I'm good! Thanks. Waiting for my SCV to arrive. Hopefully that'll stop the stupid hunting.
Yes, I think that will be fun :shock:
By the way, the mechanic I've just started using near me says the seals for the diesel injectors are always copper.
Also, I have diesel pooling around the injectors, it looks quite bad, although what do I know?
Karst
Postby daraioj » Sat Jun 23, 2018 9:25 am
Yeah it's quite common.
There's two seals.
9229A is the copper washer.
Then there's a rubber seal on the crankcase cover. (Doesn't appear in the picture)
In my opinion the best thing to do is remove injectors, have then cleaned and tested. Clean or recut the seats on the cylinder head. New copper washers, clean the rubber seals on the crankcase cover.
Refit injectors. Replace the clamps for the upgraded ones if it's not been done yet (they're about £10 each at ford). New bolts torqued properly... Do a pilot learn and forget about it!
daraioj
Postby daraioj » Sat Jun 23, 2018 9:32 am
Btw, the clamps have their part number stamped on them. Ppl at ford will be able to tell you whether they're the old ones or not.
Should be 6C1Q-9L535-AC for the old ones and 6C1Q-9L535-AD for the new ones.
daraioj
Postby scottie » Sat Jun 23, 2018 10:19 pm
Mikexx wrote:
knobby1 wrote:
You'll fail your next MOT from May 20th if your EGR is still blanked..!
How will they know?
mine has been blanked for 3 yrs now, this year i had to turn the light of when i arrived at the MOT station so it would stay out for the test :lol:
scottie
Postby Karst » Sun Jun 24, 2018 12:15 pm
All change, no work on the Transit today :x
I don't think I'll ever buy another van again.
This one has been too much trauma and work already.
I don't fancy going through all that again :oops:
Karst
Postby daraioj » Sun Jun 24, 2018 12:27 pm
I think the problem is finding one that's been properly looked after.
I guess once you get it all sorted and running well all it takes is regular maintenance and a bit of care every now and then.
daraioj
Postby Karst » Sun Jun 24, 2018 12:35 pm
daraioj wrote:I think the problem is finding one that's been properly looked after.
I flipping flaming flipping well hope so! :D
Karst
Postby Karst » Fri Jun 29, 2018 7:38 pm
I took the danged thing in for a service this week, and they found £2,000 of work that needed doing to it. That included changing the injector seals. I got £750 of the most urgent stuff done, than the rest I'll have to stagger through the year.
I mentioned this to the solicitor dealing with my claim against the dealer, it seems they can take this into account.
Got the top door-hinge location ground down recently though, so the door fits a bit better.
I would no way be brave enough to change the injector seals myself. He said invariably the rubber seals that are also there will break up and needs replacing, and they're £35 each. I would probably drop stuff down into the cylinders.
So I know they need replacing now, because oil is pooling at the injectors, being forced out under pressure, and yes, it makes it run a bit ropey and smokey.
https://photos.app.goo.gl/kaRURfU9p9cAGre2A
Karst
