That sounds fine.Karst wrote:I've got USB serial Port COM 13 showing in Device Manager when I plug the lead in. This is the same as in the "Instructions" with the lead, under Ftdiunim
When i unplug it this disappears.
Karst wrote:There's really nothing to report from the log on Forescan. It just says "Unable to connect to vehicle. Please make sure the ignition key is ON and try again." That's it, the same every time.
It looks to me like there is something in the van blocking the connection.....?
It's Window 10, 64bit, and the driver I've got going in it right now is CDM21228. I did actually download your one earlier - couldn't find an executable file in it! I think it had to be paired with another download for installation. I did it somewhere along the line....
As much as I do not know what the problem is with the connection to your vehicle's ECU, I strongly believe that the only last owner of your (or any other) vehicle will do such thing. With the help of the host of gurus on this forum, you will certainly find a way out of this tight-corner.abiolayunis wrote:My van is ex-Post Office, do you think they've done something to it to block me out?
Sent from my TECNO F2 using Tapatalk
No worries Karst. I'm sorry I can't be of any more help. It's hard from the distance.Karst wrote:Hi daraioj,
Sorry for taking so long to get back to you. I thought I'd posted a reply more than 2 hours ago!
It doesn't show anything about checking ports, it just acknowledges the adaptor, and says it cannot connect to the vehicle. That's it.
It's not my laptop so I'm not very flexible about using it. And trying to post photos and screenshots is going to be a bit more involved, but I can see I'll have to go down that route. I've now given the laptop back, but I can borrow it again almost anytime, I just can't borrow it for longer than 24 hours at a time.
Tapatalk is next to useless for me, it always takes so long to load on my phone (Huawei honor 7, Android) that I rarely use it.
Many thank yous for all your time and help!
Karsty.
Give us a shout, I'll be happy to help.Karst wrote:abiolayunis - I know, these guys here are amazing!
daraioj - thanks again..... I have just taken the plunge and bought a second hand laptop on eBay. So When that arrives I'll have more flexibility, and I'll properly go through your posts here....
tbc.....
GOLDIE1B wrote:Hi I.had excessI've.smoke. under acceleration from my one. T280 copper injector seals cured a whole lot on.mine
Those are the ones. You'll have to clean the seats though or recut them and you'll need new bolts too as they're one use. And you might as well replace the clamps for the upgraded ones while you're at it.Karst wrote:GOLDIE1B wrote:Hi I.had excessI've.smoke. under acceleration from my one. T280 copper injector seals cured a whole lot on.mine
Thanks Goldie. I will be covering every option! Laptop arriving in the next coupla days, so then I can try again with all the ODB port stuff in my own time.
Did you fit them yourself? So basically, these would do the job?.....https://www.ebay.co.uk/itm/4-OF-O-E-FUE ... Sw-olaSvRQ
