Stickers stuck
Stickers stuck
Postby elv » Tue May 08, 2018 8:54 am
Just picked up an ex-utility van with reflective red/yellow chevrons all over it. Anyone know the best way to remove them? I'm guessing a heat gun and/or WD40 but unless someone has some pearls of wisdom to an easier solution. Van is 2010 so they've been on for roughly 8yrs...
elv
Stickers stuck
Postby bulls in transit » Tue May 08, 2018 9:26 am
Found petrol was good at removing old stickers/glue on mine, then good cut and polish. ( that’s on 50 year old cellulose,can’t see where sticker were now even in sun), bit of heat for should peel easy,petrol on rag for glue.
bulls in transit
Re: Stickers stuck
Postby Andy133 » Sun May 20, 2018 8:58 pm
Heat gun, take your time. Get it warm enough but not to hot and it will come off easy and won’t have any glue left on. Wear a glove I burnt my fingers when I heated it to much
Build Date: 04.09.2001
Vehicle Line: Transit 2000-2006
Cab Style: Regular Cargo Van
Series: 350M Series
Engine: Duratorq DI 2.4 (90PS)
Transmission: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 5.13
Andy133
