by Mattyk113 » Tue May 15, 2018 1:08 pm
It would seem I've got a power steering leak. Upon first look the rack was soaked which led me to think the worst. However when I took the wheel off and cleaned everywhere up it seems it's one of the 2 pipes to the rack. With the small clip attached the bottom one had the drip on but when I removed the small clip and started the engine the top one had the drip, I understand the top one is the low pressure return? And as it's not spraying out under pressure, it's more one drip every 10 secs I assume this is my leak. I've seen them online, so my question is... How hard are they to fit? I'm not a mechanic, I'm a plumber! Got a jack and stands and a socket set, does anything else need to come off to change it or will the pipe thread through it's route easy enough? Any tips would be great!
