by olympia5776 » Wed May 23, 2018 8:00 pm
Some will say yes and no doubt, some no.
Me, I closed off as many as I could.After spraying waxoyl into these cavities for so long I hope that the internal surfaces are coated therefore if there is any moisture due to condensation then it will lay on thw waxoyl thus hopefully causing no rust.
I guess you just have to do your best ,check it regularily and keep the rust proofing as intact as you can.
Just as a note , I now make my own "waxoyl" using finely grated candle wax, white spirit and chainsaw oil. Google it and you can get the recipe .
It seems to cling ,and run if you dilute it enough , and after using it for two years now It looks like it'll do the job.
