blanking off a pipe-help
Postby alloageorge » Sun May 20, 2018 10:33 am
in the distant past someone cut and crimped the one inch pipe which
feeds the egr. over time this has melted a hole in the inlet manifold
that it was touching.i've taken off the manifold and now want to
blank off the pipe properly.as i need to fit something over the end
of the pipe and "glue" it in position,what would be the best solution.
pipe will obviously be hot and under pressure.
thanks for any suggestions.
alloageorge
Re: blanking off a pipe-help
Postby Brains_transit » Sun May 20, 2018 1:19 pm
When I blanked my egr I cut the ends of the flexible pipe and bolted one to the egr with a blanking plate and same as the exhaust manifold
Brains_transit
Postby alloageorge » Sun May 20, 2018 2:33 pm
I can almost hear the banjo music.plugging it redneck style.
bit of holts and it should be good.
alloageorge
Postby dumper » Mon May 21, 2018 2:20 pm
With the new mot rules the egr has to be in working order or it will fail
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby alloageorge » Tue May 22, 2018 3:45 pm
how can they tell?i thought it was a visual check for smoke from the exhaust?
alloageorge
Postby dumper » Tue May 22, 2018 5:56 pm
If the pipe is cut and blanked off and you can see it is then yes it’s a fail same as the cat has been cut and welded up
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Brains_transit » Tue May 22, 2018 6:03 pm
dumper wrote:If the pipe is cut and blanked off and you can see it is then yes it’s a fail same as the cat has been cut and welded up
I'm going to lose my bonnet key :lol:
Brains_transit
Users browsing this forum: Bing [Bot], Google Adsense [Bot]
