Does anyone know what this is?
Postby marc1234567 » Mon May 21, 2018 10:25 pm
I have put a replacement engine in and this has oil leaking from it and I am not sure it should and where I could put it.
someone said they thought it might go on a slam panel?
should there be oil coming from it? it has a gold coloured drill bit in it. ( I put that in to stop the oil coming out) the tube seems to go into what seems to be a vacuum pump ( it's above the water pump on the right hand side of the engine)
Many thanks.
Previous mk 5 (2000) Luton body (2012-2013)
Mk 6 tddi 2.4 125ps RWD dropwell luton (2018 - present)
Mk 7 tdci 2.2 125ps RWD Luton / taillift (Aug 2021-present)
marc1234567
Re: Does anyone know what this is?
Postby Frag » Mon May 21, 2018 11:31 pm
It should go to a solenoid on radiator cowl,egr valve control.
It's teed into servo vacuum feed,then goes to egr valve
Frag
Ford Technician
Postby marc1234567 » Mon May 21, 2018 11:36 pm
Frag wrote:It should go to a solenoid on radiator cowl,egr valve control.
oh . so it shouldn't have oil coming out?
marc1234567
Postby marc1234567 » Tue May 22, 2018 10:40 am
Would it make a difference if the belt was not attached to pulleys. I've not attached yet.
marc1234567
