locked out of my can't get to my tools
Postby jimmy085 » Tue May 22, 2018 11:01 am
hi lads need a bit of help can't get into the back of my van (mk7 transit 100 350)
I had the usual central locking problems van beeps and wouldn't open/close got it sorted before using forscan and a modified Bluetooth elm 327 but today same problem back of the van won't open tools locked inside and forscan says it's a B1090 saying circut voltage to below threshold any one any ideas
jimmy085
Re: locked out of my can't get to my tools
Postby bigjohnthomas » Tue May 22, 2018 11:05 am
Only one thing for it
bigjohnthomas
Postby jimmy085 » Tue May 22, 2018 1:01 pm
bigjohnthomas wrote:Only one thing for it
thanks but my cordless grinder is in the van
jimmy085
Postby v8dave » Tue May 22, 2018 6:12 pm
I assume you can get into the front of the van ?
It might be a dirty joint in a connector.
Open and remove the glove box, drop the fuse box down to expose the bcm.
Unplug the upper large connector on the right, you slide the lever in the middle across to unlock it.
Reconnect it.
Do the second connector down on the left as well.
Check all your fuses.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Postby jimmy085 » Tue May 22, 2018 9:42 pm
v8dave wrote:I assume you can get into the front of the van ?
Reconnect it.
thanks for that v8dave I'll try that 2moro hopefully it works
jimmy085
