loot wrote:Are you sure you mean brown wires and not brown trousers?
The only wires you will worry about are the centre ones for the airbag, but the srs module is quite clever and as the vehicle is not moving you can't accidentally set it off, the other wires are just the horn so it'll either be correct or the horn will honk when you connect the wire.
